KDX 125 exhaust
Posted: 04:19 am May 17 2020
by 2strokemark
Hello guys, Im looking to change pipes on my 125 anyone has some reccomentations.I cant find anywhere aftermarket exhausts for my 125
Re: KDX 125 exhaust
Posted: 07:25 am May 27 2020
by Dan 250sr
Kx 125 ? And adapt exhaust port to take o ring fitting instead of flange? My kdx 250 original exhaust was a flange fitting... I used 12mm thick aluminium plate . Cut to the shape of the original flange. Cut hole for fmf exhaust. Remove the two studs and use Allen key bolts to bolt aluminium flange on.. recess Allen key bolt so flush with flange... also need to make tabs on aluminium plate for exhaust springs..... also compare kdx and kx 125 shape to make sure they are the same.... kdx 250 and kx 250 are identical apart from the exhaust port end... Japanese version sr... I am sure us kdx is different again
Re: KDX 125 exhaust
Posted: 11:37 am May 27 2020
