Water pump shaft
Posted: 10:46 am Jan 12 2020
by andytom1969
Hi all. My 250sr is getting water into the case past the water pump seals because the shaft is quite badly scored. The shaft is no longer available. Does anyone have any ideas for repairing it?
Re: Water pump shaft
Posted: 10:07 pm Jan 12 2020
by bufftester
With no availability, as I said in the previous post, may be able to have a shop fill the score and turn the shaft back down to dimension. Not sure if JB weld would hold up in that application
Posted: 06:08 am Jan 14 2020
by kdxsully
JB weld won’t work.
Posted: 02:48 pm Jan 14 2020
by Molly's 70
Negative on the JB weld. I would tig it up & put on a lathe. After it gets machined down, you could polish it with emory cloth while spinning.
Posted: 10:39 pm Jan 14 2020
by kdxsully
Molly's 70 wrote: ↑02:48 pm Jan 14 2020
Wouldn’t it wear down again pretty fast without the chrome?
Posted: 04:32 am Jan 15 2020
by Molly's 70
kdxsully wrote: ↑10:39 pm Jan 14 2020
Maybe, but it would work for quite a while. I would have to look at a good filler rod selections.
