Hey kdx250 1991 SR model kx250
Posted: 08:35 pm Nov 24 2019
by Stevetooms
Does anyone know if a kx250 carb and piston kit will work and fit into my kdx250 1991 SR model thanks
Re: Hey kdx250 1991 SR model kx250
Posted: 09:59 pm Nov 24 2019
by kdxsully
No idea. Are the part numbers the same? Check partzilla for the part numbers of each respective bike. You might need the carb boots as well
Posted: 11:39 pm Nov 24 2019
Please do not post the same or very similarly worded question in multiple subforums.
Sorry that you have not received more help for your unique model.
Posted: 05:19 am Nov 25 2019
by Stevetooms
Hey thanks for your help
Posted: 06:21 am Jan 10 2020
by Dan 250sr
Change inlet manifold to 38 and a kx carb will work.. kx 250/ 500 inlet manifold are 38 ... your con rod small end is a different size to a kx . One is 18 mm bearing and the other is a 19 mm bearing... also kx wrist pin is in a different place to kdx piston.. you can fit a kx con rod and a earlier kx barrel 89 /90 . 70 mm stroke/ 91 92 use 72 mm stoke so won't work unless you machine top of barrel. I had my head machined to lower squish gap .
Posted: 08:27 am Jan 10 2020
THANK YOU, DAN!!
Posted: 11:10 am Jan 11 2020
by Dan 250sr
No worries hope it helps
