Kdx200sr KIPS Valves/Piston/Rings - Sourcing parts?
Posted: 05:10 pm Sep 10 2019
by Spoogebob
Hi all,
Had my kdx around 9 months and decided to have true engine torn down and rebuilt as it was well overdue! Sure enough the top end needs replacing, KIPS are stripped/snapped and I need a new con rod... Trouble is
I’m having a real hard time finding parts? Having looked up part numbers for the piston/kips etc they seem to all differ from those specified for the E-series (which has parts more readily available).
Does anyone here know if the KIPS are the same across models? (I’m trying to source steel replacements)? Also, does anyone know where I can get a piston kit which will fit/work?
Re: Kdx200sr KIPS Valves/Piston/Rings - Sourcing parts?
Posted: 08:20 pm Sep 10 2019
Welcome to kdxrider.net.
Look at BDK Engineering in the UK. They might know if the subvalves they make will work on your model.
Good luck.
Posted: 04:59 am Nov 03 2019
by Hooters
I've ordered some KIPS valves from motoduro.. Should be here soon so I can let you know how they go in my SR when they get here.
Posted: 08:51 pm Nov 17 2019
by Hooters
I got the valves. They seem well made and everything fits as it should. They are with cylinder at the re platers at the moment so I havnt re assembled it yet. Will keep you posted.
Posted: 10:39 am Nov 25 2019
by Stevetooms
How did you get on pal
Posted: 12:04 pm Feb 13 2021
by Spoogebob
Stevetooms wrote: ↑10:39 am Nov 25 2019
Sorry for the late response! I got my valves from BDK and my local shop sourced and fitted a non SR piston (SR piston isn't available!). All assembled and running... although the cylinder needs replating (I didn't have time to wait!) - next build is gonna be a little pricier!
Where are people getting there cylinders plated (in UK)? Langcourts have been recommended to me...
Posted: 01:34 pm Oct 11 2023
by Tokyotim
Hello sorry to necro, do you know if the Japanese model 220SR and 220 US model have the same piston?
Posted: 09:18 pm Oct 11 2023
Doesn't the SR have three rings or an oil ring or something like that??
Posted: 01:24 pm Oct 12 2023
by JimmyB
KDXGarage wrote: ↑09:18 pm Oct 11 2023
The part #s for the piston and rings list the same for both the US/Canada 220r and Japan 220SR models going from NA and Japanese web sites (Kawasaki Japan, Impex,Webike), IIRC the OEM 220 piston in my bike(02 220) did have something like a expander spring under the bottom ring similar to some 4-stroke bottom oil control rings, I have not seen a aftermarket piston for the 220 with that expander spring, just normal rings.
Posted: 12:56 pm Oct 13 2023
by Tokyotim
Hmmm so replacing my piston to prevent the grenade might be a problem
Posted: 12:59 pm Oct 13 2023
by Tokyotim
JimmyB wrote: ↑01:24 pm Oct 12 2023
