Oil Injection
Posted: 06:46 am May 14 2018
by jstcraig
I have taken some time and searched the forum for all things oil injection.
There is a consensus that if it ain’t broke don’t fix which I completely agree with but there are more than a few posts that have when the oil injection stopped working.....
So the question I pose to the forum members who are familiar with the system is what actually fails, what do those of us that have oil injection on our bike need to pay particular attention too to prevent system failure.
Re: Oil Injection
Posted: 03:13 pm May 14 2018
by bufftester
I don't have any experience with the SRs, but I did have an old Suzuki TS185 that had an oil pump, and my Kawasaki jet ski has a similar type oil pump. On the Suzuki the biggest problem was just having the oil line getting gunked up where it goes into the carb. Seemed if it sat for awhile the gas and oil didn't play well and it would plug up. On the jet ski it was the pump impeller that would wear, but I don't believe the SR pump is the same type. If you can find a service manual it should give specs on pressure output , etc. Unfortunately in the KDX universe a lot of us have never seen one in the wild!
Re: Oil Injection
Posted: 09:30 am May 15 2018
by jstcraig
bufftester wrote:I don't have any experience with the SRs, but I did have an old Suzuki TS185 that had an oil pump, and my Kawasaki jet ski has a similar type oil pump. On the Suzuki the biggest problem was just having the oil line getting gunked up where it goes into the carb. Seemed if it sat for awhile the gas and oil didn't play well and it would plug up. On the jet ski it was the pump impeller that would wear, but I don't believe the SR pump is the same type. If you can find a service manual it should give specs on pressure output , etc. Unfortunately in the KDX universe a lot of us have never seen one in the wild!
On closer inspection of the Sr parts fiche I’m no closer to understanding the internal machinations of the oil pump, there is an idler gear that looks like it drives off the clutch drum, this leads me to think that it’s a combination of throttle positioning and low pressure draw of the two stroke cycle. That may seem obvious to most but until I pull it apart I don’t know Jack, so I will heed your advise and replace all the connecting hoses, do you think regular fuel hose would suffice, the ones insitu at present are rock hard.
Re: Oil Injection
Posted: 01:22 pm May 15 2018
by Julien D
Not sure exactly about the SR, but most have the pump gear driven off the crank or clutch. Engine RPM determines pumps revs per minute, throttle position controls the amount of oil pushed per pump revolution. Very neat setup.
Re: Oil Injection
Posted: 02:23 pm May 15 2018
by jhogg7575
There is a set up pic somewhere on how to check the throttle cable ajustment at the pump will see if i can find it
Sent from my SM-G935F using Tapatalk
Re: Oil Injection
Posted: 02:27 pm May 15 2018
by jhogg7575
This was found while serching internet would like to thank original poster hope they don't mind repostImage
Re: Oil Injection
Posted: 08:47 pm May 15 2018
by jstcraig
jhogg7575 wrote:This was found while serching internet would like to thank original poster hope they don't mind repostImage
Sweet set up, will be replacing all the hoses as suggested in jhogg’s post, have had contact with PO and it was working last century lol
Oil Injection
Posted: 07:04 am May 21 2018
by jstcraig
Hoses on and oil in, will let it sit over night to see if it moves further along, the brass fitting in the manifold is a check valve, mine unfortunately even after cleaning passes both ways and this might be where they fail maybe any thoughts if you read this post ??
Sent from my iPhone using TapatalkImage
Re: Oil Injection
Posted: 02:09 pm May 21 2018
by jhogg7575
I got mine to bleed thru buy holding the throttle fully open while kicking over the engine with the fuel off and the spark plug out took about 10 mins
Re: Oil Injection
Posted: 03:49 pm May 21 2018
by jstcraig
jhogg7575 wrote:I got mine to bleed thru buy holding the throttle fully open while kicking over the engine with the fuel off and the spark plug out took about 10 mins
Thanks trying that method, didn’t see any movement past the pic
Re: Oil Injection
Posted: 05:36 am May 22 2018
by jstcraig
Well I’m going to premix for the time being, the check valve is not functioning correctly, waiting for parts from Japan
Oil Injection
Posted: 05:19 pm May 23 2018
by jstcraig
Will have to repair the oil tank, have noticed a leak at the outlet, maybe due to being < 5mm above the exhaust. If you read this post and have an Sr could you put up a pick of your tank on the bike so I have a reference point, I think the exhaust might be buckled
Sent from my iPhone using TapatalkImageImageImage
Re: Oil Injection
Posted: 02:05 am Dec 10 2018
by Hooters
Hi
Just wondering if someone can shed some light on the oil injection system for me.
I have a clear hose between the oil pump and the manifold.
When the bike is running, the hose is never completely full of oil along its entire length. It's full from the pump to about half way then splatters from the halfway point to the manifold.
Does anyone elses look similar?
