KDX200SR
hi-def
- Country: New Zealand
Re: 1990 KDX200SR
I have almost finished my supermoto wheel set just waiting on tyres and a few other bits
- Has thanked: 141 times
- Been thanked: 36 times
Re: 1990 KDX200SR
Man. That's wide.
hi-def
- Been thanked: 10 times
Re: 1990 KDX200SR
You may want to fab up a shield, that chain is going to make contact with the rubber being that close. Middle of the span you can easily get 5mm of lateral play. Better to rub a replaceable shield than your tire.
hi-def
Re: 1990 KDX200SR
Don't worry, I have a guard I'm in the process of fitting.
- Tyl3r
Re: 1990 KDX200SR
Love it, looks awesome!
I was able to get a TM Design chain slider on my KTM that has a rub guard built in to protect the chain/tire. I don't think they make those for the KDX's, but I'm sure you could build a guard up that would share the chain slider holes if you wanted to.
hi-def
Re: 1990 KDX200SR
I did a little bit of work on the bike recently, tried out some black fork guards, looks good with the black rims I think.
And changed the fork springs
- Been thanked: 15 times
Re: 1990 KDX200SR
Your front brake line is missing it’s stiffener sheath. It will bend and kink now every time the front forks are compressed. Dangerous. Replace that brake line before you go riding again.
