Kdx200sr KIPS Valves/Piston/Rings - Sourcing parts?
Spoogebob
Country: United Kingdom
Post by Spoogebob » 05:10 pm Sep 10 2019
Hi all,
Had my kdx around 9 months and decided to have true engine torn down and rebuilt as it was well overdue! Sure enough the top end needs replacing, KIPS are stripped/snapped and I need a new con rod... Trouble is
I’m having a real hard time finding parts? Having looked up part numbers for the piston/kips etc they seem to all differ from those specified for the E-series (which has parts more readily available).
Does anyone here know if the KIPS are the same across models? (I’m trying to source steel replacements)? Also, does anyone know where I can get a piston kit which will fit/work?
Re: Kdx200sr KIPS Valves/Piston/Rings - Sourcing parts?
Post by KDXGarage » 08:20 pm Sep 10 2019
Welcome to kdxrider.net.
Look at BDK Engineering in the UK. They might know if the subvalves they make will work on your model.
Good luck.
Hooters
Country: Australia
Post by Hooters » 04:59 am Nov 03 2019
I've ordered some KIPS valves from motoduro.. Should be here soon so I can let you know how they go in my SR when they get here.
Hooters
Country: Australia
Post by Hooters » 08:51 pm Nov 17 2019
I got the valves. They seem well made and everything fits as it should. They are with cylinder at the re platers at the moment so I havnt re assembled it yet. Will keep you posted.
Stevetooms
Post by Stevetooms » 10:39 am Nov 25 2019
How did you get on pal
