Bike just stopped running mid day
Posted: 09:53 am May 09 2022
I’m baffled by this. So as I’m prepping my 2000 KDX 200 to run a hare scramble this weekend, I started the bike and it ran on the 3rd kick after sitting over the winter. I let it warm up, ran it around the yard, then drained the oil. I filled the oil back up and it hasn’t run since. Here is what I then did and what I observed:
• Put new spark plug in; confirmed it was getting spark.
• Drained the carb bowl, cleaned the bowl, removed and blew out the main jet and pilot jet; then generally cleaned the carb.
• Cleaned the air filter and air box (I occasionally get a mouse nest at the bottom of the air box over winter) – confirmed it had clean path to
the carb.
• Drained the gas and replaced with fresh Premium gas and premix.
• Confirmed the gas ran through the petcock and into the carb.
• As I kicked and kicked with no start, I noticed unspent gas/oil leaking from the exhaust pipe head (where it connects to the cylinder) – I
probably need a new gasket/washer, but I have seen that before and bike still ran fine. So I took off exhaust pipe, cleaned it and put back.
• I noticed some carbon build up at the exhaust port and a little bit of black on the piston just under the rings.
• When it was running, I was goofing with the air screw – it was idling low.
The most baffling thing is, the bike was running perfect until I changed oil. Now it doesn’t even sound like it wants to turn over; like it’s not getting any spark, gas and/or air. I did the top end many years ago and the bike has always started in the first 5-10 kicks all these years. It’s never just stopped running, after running earlier; it’s been pretty bulletproof all these years.
I’m trying to get it running before Sunday; any insight is greatly appreciated. Thanks KDX'ers!
the carb.
