Clutch actuator not actuating
Hey all! I’m putting my clutch cover back on and realize that I have very little clutch pull and after about 1/4 of an inch it is stiff. What I’m wondering is, does the clutch actuator arm have to go in a certain way and if my return spring is placed correctly thanks!
- ACA0D902-1438-49A7-87B4-696804BCF1F1.jpeg (2.97 MiB) Viewed 1489 times
- CA4A0454-3688-4DB5-AE07-CE73DCA1BB34.jpeg (2.73 MiB) Viewed 1492 times
- 0BE2E59E-6132-4F89-9B8C-7C5E5EED0F6F.jpeg (2.99 MiB) Viewed 1492 times
- 0D30FEB6-EAAB-4079-B212-807C7B0E2355.jpeg (2.81 MiB) Viewed 1492 times
Re: Clutch actuator not actuating
Your actuator looks to be correctly oriented. What did you torque your clutch spring bolts too? Did you remove the clutch while the cover was off?
- Country: New Zealand
Yeah i'd check the torque specs on your springs - if too tight can cause a tough pull. Also just check your cable slack.
Why was the cover off? Any chance you installed EBC heavy duty springs? i had this happen to me and had to swap them for a new set of OEMs
