Help with washer location after case splitting
Posted: 03:46 pm Mar 27 2020
by Chevydawg1
I just split the case on my 05 220 because the Piston skirt broke then cracking the left case. After splitting the case a washer dropped out. I checked the manual and exploded transmission view but can't seem to locate it. It only fits the input shaft where it enters the bearing the right case. Here is a picture where it may go. Is this correct? Also, should I buy just the left case or find a matching set? Thanks for your time!
Re: Help with washer location after case splitting
Posted: 05:56 pm Mar 27 2020
by Chevydawg1
Found it...I guess it was stuck behind clutch basket and I missed it. Bumping the case with a rubber mallet while splitting the case must have caused it to fall off.
Posted: 09:03 pm Mar 27 2020
by kdxsully
Glad you got it. Usually cases are machines for each other, so a matched set is the way to go.
Posted: 04:01 am Mar 28 2020
by Molly's 70
I would try to TIG weld the cracked case.
Posted: 07:37 am Mar 28 2020
by kdxsully
Molly's 70 wrote: 04:01 am Mar 28 2020 I would try to TIG weld the cracked case.
Wouldn’t that depend on location?
Posted: 10:28 am Mar 28 2020
by Molly's 70
kdxsully wrote: 07:37 am Mar 28 2020
Yes it sure would. I'd like to see a picture. I could be wrong but, I bet it can be welded.
Posted: 06:34 pm Apr 03 2020
by Slick_Nick
Yeah always replace them as a set, but if you can repair your cases without warping them it’s probably more cost effective.
