Q7: air filter element fit "01 KDX220"
Posted: 04:47 pm Jun 10 2018
by freeindeed
I bought a new twin air filter for my project 2001 KDX220.
The twin air filter has about a 1/8" hole for mounting.
The air filter cage has about a 1/2" diameter brass fitting.
Is the filter supposed to be "stretch fit" over the brass fitting on the end of the air filter cage?
Or does the filter remain on the outside of the brass fitting and a large washer supposed to press against it to seal out air leaks?
Q7: air filter element fit "01 KDX2200
Posted: 04:53 pm Jun 10 2018
by SS109
The hole should be stretched over the larger brass piece.
Re: Q7: air filter element fit "01 KDX2200
Posted: 05:11 pm Jun 10 2018
stretch over
Is this 20 questions? :mrgreen:
Re: Q7: air filter element fit "01 KDX220"
Posted: 11:48 pm Jun 14 2018
by freeindeed
OK thanks.
It worked without ripping the air filter. Just move slowly and carefully.
So I did not have to call Twin Air about a ripped filter element.
But I did call No toil to report the air filter oil was neither red nor green.
Could be getting up toward 20 questions.
I figured I'd ask 100 questions on this relatively low mile build. Like when I looked at about 100 houses before I bought my 1st house.
But using search has spared you from some questions.
Posted: 12:06 am Jun 15 2018
Ask away. I just noticed that you were numbering them.
I am a big question asker at times, so no worries from me. :oops:
I would put a dab of grease around the brass fitting. I did not think of that during my last reply.
