how different is a h model pipe to a e
theres a bill pipe localy for a h series wondering how different it would be from one for a e sereies mine is an sr so i will have to mod wharever pipe i put on as it has a flange to mount the pipe rather than springs and seals
beware the mighty kdx
They route differently and won't clear the shock I believe...
It would be great to have someone with specific knowledge of a Bill's pipe on an 'H' SR fitting an 'E' bike..
..but don't hold your breath. Not that anyone is withholding information..just that I doubt anyone has the slightest idea.
Probably safe to say it's so different as to be not at all the same.
Consider simply US models..you won't be putting an 'E' pipe on an 'H' model.
Well...unless you start with a flat sheet of metal and make it from scratch. In that case (starting with flat metal) they're pretty much the same!
Good luck!
Good luck!
cheers I know it was a bit hopefull but its always possible someone has held a h pipe up to there e and found it to be realitivly close stranger things have happened
the pipe is around a third of new price but this "They route differently and won't clear the shock I believe..." tell me its not worth the effort
