Air Screw Question
Johnny
Air Screw Question
Post by Johnny » 12:11 pm Dec 14 2006
Two questions:
1.) What is its purpose and how does it work?
2.) Mine was 6 full turns out from its seated position. I have KDX220 with the bored carb to 35 by Fredette. Just wondering if this seems right?
The bike runs great and I have never had any problems with the carb, it just seems like 6 turns is alot especially when the manual says 1.5 turns.
Thanks,
John
m0rie
Post by m0rie » 12:19 pm Dec 14 2006
Yeah that doesn't sound right at all. What jets/needle do you have in the carb?
1989 KDX 200
2007 TTR-50E
Johnny
Post by Johnny » 12:26 pm Dec 14 2006
Not sure. Haven't had it apart, just bought the bike used in August have been riding it but not to much taking things apart. I am saving that for the winter (give me something to do while its snowing). Also, this is my first dirt bike so I am kind of learning as I go . I have already learned so much from this forum.
What air screw adjustment is considered "normal" for modified carbs such as mine?
m0rie
Post by m0rie » 01:05 pm Dec 14 2006
Functionally you should be using the same adjustments as a stock 35mm PWK. Right around 1.5 for a starting point. However your jetting should have changed a bit with the larger carb size. Your wacky air screw setting could be masking bad jetting or more likely an air leak.
1989 KDX 200
2007 TTR-50E
Johnny
Post by Johnny » 11:35 am Dec 18 2006
Yeah, I counted the turns wrong. It was really only 3 FULL turns out. For some reason, I was counting 180° as a turn. Anyway, I backed her down two 2 (full) turns, adjusted the idle, and it runs great. I also did alot more research and was able to answer my own questions. (I should have done that in the first place). So, I don't habe no leaks, (as turing the screw effected the bike in the proper range) and I my pilot jet is the right size.
Thanks for the response.
grump99
Post by grump99 » 01:03 pm Dec 18 2006
Good deal! :supz:
