Moose swingarm bearing "shims?"
- strider80
I bought a set of moose swingarm bearings (I know I know, chinese) and they can with 4 thin round shim/washers that look like they are supposed to go between the seals and frame or swingarm and engine. The bike did not have them originally. Anyone know what they are?
2005 KTM 250EXC
2000 KDX200 (gone)
2000 KDX200 (gone)
I'm searching my mind but I think they go between the bearing and the seal.
I say this because I had some Pivot Works bearing kit that I was installing on a bike and they had the thin shims. I forgot how I figured out where they went (maybe it was in the instructions) but I'm 95% sure that in my application they went in the outer side of each swing arm bearing PRIOR to installing the related seal.
EDIT - Forget the above - CC's thread is likely 100% correct.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
- KDXer
- KDXer
http://kdxrider.net/forums/viewtopic.ph ... ht=washers
canyncarvr wrote:
The four washers are quite thin, right? They are used in KX250s between the pull rods and the knuckle/swingarm. They are not used in an OEM 'H' model KDX. Ha!...the bolts are too short as it is! The KX250 bolt shoulders are considerably longer. I use them..KX250..bolts in my 'H' unitrack with my Devol pull rods with those washers.
![Image](http://img138.imageshack.us/img138/7665/sydney030507zx7.jpg)
- strider80
Thanks Trev! I got all the linkage and swingarm bearings installated last night, what a pain! I don't look forward to ever doing that again. My old bearings were all pretty shot (looked like yours the other thread), with the shock bearing being totally grenaded and a screwed up rocker arm. Hopefully with lots of good grease they will last awhile.
2005 KTM 250EXC
2000 KDX200 (gone)
2000 KDX200 (gone)
I'm confused.
Well, (whew) at least something is normal.
The shims I was talking about go on the knuckle if you use KX style bolts..like on Devol pull rods. Not the swingarm.
The kit you got may well 'fit' different models. Cheaper to make one kit fit different bikes than to make kits specific to every model.
No reason to replace washers/shims. If your bike didn't have 'em...don't worry about it.
It's been awhile..and I didn't look it up...but the 'H' model DOES have some sort of washer/spacer setup in the swingarm...right? You could see 'em easy enough at the buykawi site, or in your manual.
If I wasn't lazy, I'd look in my manual. But...your bike is already back together, so...too late now anyway!
- strider80
- strider80
