Gear Levers.
cfspawn
Gear Levers.
Post by cfspawn »
Hey all.
Just wondering If anyone has had experiences with MCS gear levers. mines busted and looking to be replaced they are quiet cheap compared to OEM and also other brands. i have also been told they are steel any comments would be appreciated.
:twisted:
KDXer
Post by KDXer »
I think they are an aussie lever but I could be wrong. :wink:
cfspawn
Post by cfspawn »
Yer. for $25 AUD see what happens
KDXer
Post by KDXer »
Sure beats the $65 I payed for my IMS replacement. :evil:
cfspawn
Post by cfspawn »
Could be a quality thing though Trev. soon find out :rolleyes:
krazyinski
Post by krazyinski »
my OEM broke the spline clamp, is this normal ?
cfspawn
Post by cfspawn »
Thats the problem with mine.
KDXer
Post by KDXer »
And mine... :roll:
krazyinski
what I did was went and purchased a cheap lever MSR like and cut the spline clamp off of the oem and the new one and welded the new clamp on the old shifter. just use a bolt and two washers to protect the splines from slag, the oem bolt will hold it in the right spot then weld away.
