Idle screw all the way in-Air Striker PWK35
Posted: 10:41 am Nov 23 2022
Replaced the stock carb a few years back with an air striker. Big improvement. However the Idle screw is almost all the way in. Both carbs need(ed) the 35 pilot, roughly 2-1/2 turns out. I think the slide height is overriding the idle circuit (thru the needle circuit) thus the lean pilot jet. The slide is a 4.5 with DEK needle. Stock was setup with a 5 with CEL and 35 pilot.
My question is would a different slide cutaway bring the idle screw and the pilot jet back to a more normal centralized setting. What slide are others A.S. carbs owners using?
Bike is temperamental to the daily weather and elevation changes. It has a surge coming off 2-3000 RPMs otherwise runs clean up into the powerband hit. Pipe is A PC II, stock reeds, air box lid off. Compression and leak down are good. 2004 KDX 200. 4000' elev.
