Plug color only indicates how the jetting is for the RPM range you use the most. For most people that is high RPM which means it indicates whether the main jet is too rich or too lean. That is very important but having that correct does not mean your mid throttle jetting is right, or that your jetting off of idle is right, or that your idle jetting is right. I highly recommend a good jetting calculator www.dragonfly75.com/moto/carbjetting.html to know if the jetting is rich or lean between closed and fully open throttle.
Read the color on the first half ground electrode (not at its end) and end of the ceramic insulator. Gray or chocolate brown is the ideal color.
White colored ceramic insulators are caused by
1) too lean a fuel/air mixture
2) too hot a rating for the plug
Gray colored plugs can be caused by
1) use of aviation fuel
2) use of certain synthetic oils (Super M is one of them)
Dark plug color can be caused by
1) excessive amounts of oil added to the gas (mostly with group 1 and 2 oils otherwise known as mineral oils. Go to www.dragonfly75.com/moto/oil.html to see what group oils are in the most popular 2 stroke engine oils)
2) too rich jetting
3) spark plug misfiring possibly due to bad electrical connections or a failing ignition component (CDI, high voltage coil, stator coil)
4) too cold a heat rating for the plug
Be warned about lack of coloration at the side end of the center electrode that is more than a half millimeter. That is caused by too much spark advance or too hot a plug rating. Enough spark retardation allows all of the sides of the metal electrode except for the last half millimeter to have combustion deposits on it.
Cheap gasoline without enough deposit control additives can leave strange deposits on the plug. This is fairly common in 3rd world countries but also happens in 1st world countries. (see https://www.knowyourparts.com/technical ... -deposits/ )
READING SPARK PLUG COLOR
- Jaguar
- Country: Paraguay
- Jaguar
- Country: Paraguay
Re: READING SPARK PLUG COLOR
Here's a photo of my plug using Super M synthetic oil: www.dragonfly75.com/moto/images/grayplug.png
I think my bike runs great, but this is what my plug looks like. To be fair i think I idled the bike last trying to empty the carb.
I will post one after a proper ride next time I go on one.
All that oil and carbon build up is not from one idling session. Check your float level and jetting.
Yes, the only way to get an accurate plug chop reading is to use a new plug EVERY chop.
