Page 1 of 2
KLX forks and KX Upper Clamp?
Posted: 03:21 pm Dec 28 2019
by Owyhee1
I am putting klx forks on my kdx, but want to use my rubber mounted fat bars, Does the 43mm kx top clamp fit?
Re: KLX forks and KX Upper Clamp?
Posted: 04:37 pm Dec 28 2019
Hi. Welcome to kdxrider. Thanks for signing up and posting.
I split your question out to its own thread.
I am not sure of the offset, but I think it is 1991 KX250 / 1991 - 1993 KX500 upper clamp that matches up. I think 1992 - 1995 upper clamp is about 2 mm different. (less)
Posted: 10:06 am Dec 29 2019
by Owyhee1
Thanks for the reply, I should have specified year. I have a 2003 KDX 220, I am installing 2003 KLX 43mm forks. I would like to have rubber mount bars, and possibly the double bolt bottom clamp. I read that the 94-95 KX500 triple clamp would fit. I didn’t know the offset is different, in the event I can only find the top clamp. My question is, does your answer apply to the 2003 KDX? What are my options if I want the entire triple tree without mods, or secondly, if I can only find a top clamp? Thanks for your help!
Posted: 08:00 pm Dec 29 2019
If you want to change the top, then I think it is:
This Kawasaki 44039-1212 HOLDER-FORK UPPER Not Available fits the following models and components:
Kawasaki Motorcycle 1991 KX250 - KX250-H2 Front Fork (KX250-H2)
Kawasaki Motorcycle 1991 KX500 - KX500-E3 Front Fork (KX500-E3)
Kawasaki Motorcycle 1992 KX500 - KX500-E4 Front Fork (KX500-E4/E5)
Kawasaki Motorcycle 1993 KX500 - KX500-E5 Front Fork (KX500-E4/E5)
If you want to do top and the KX bottom, you can get 1991 KX250 / 1991 - 1993 KX500 or go less offset with 1992 - 1995 KX250 with a stem swap and upper clamp insert for difference in stem OD, or find a set of 1994 - 1996 KX500 clamps (no stem swap needed). I can't remember the 1994 - 1995 or 1996 KX500 offset, but obviously, if you get the top and bottom, then it would be no problem.
Posted: 10:54 pm Dec 29 2019
by Owyhee1
Very helpful, thanks!
Posted: 11:08 pm Dec 29 2019
You're welcome.
Just remember that 1992 + KX125 / KX250 / KX250F / KLX450R / KX450F / all have the larger stem OD and a larger top bearing.
KX500 / KDX / KLX300R / 1991 and older KX125 / KX250 have the smaller top bearing.
Posted: 07:58 pm Jan 02 2020
by Owyhee1
I installed 2003 KLX forks on my 2003 KDX. Everything fits except.. I bought a 1991 KX250 upper clamp, at least that is how it’s advertised (kx500 is stamped underneath)
The offset is wrong. The best I can measure, my KLX offset is 22mm (+-) The upper clamp I received is about 26mm (+-) All other dimensions are spot on. (I know for sure it’s a kx500 clamp, 43mm)
My question is, did they send the wrong part, or does the 1991 KX250 have more offset than the KLX? And if so, is there a top clamp that bolts right up?
Thanks in advance!
Posted: 08:06 pm Jan 02 2020
Maybe I was wrong? I am not sure. Maybe it is the later clamps that work with KLX. I may have been thinking of KDX250. If so, I am sorry for the error.
Can you post some pics of what you bought?
Posted: 08:41 pm Jan 02 2020
by Owyhee1
The Answer clamp is the one I bought, marked kx500, the hard mount is the stock klx
Posted: 08:45 pm Jan 02 2020
by Owyhee1
Posted: 09:14 pm Jan 02 2020
I can't remember about the KX500 stamping.
Posted: 09:19 pm Jan 02 2020
by Owyhee1
Is there anywhere to look to find fork size and triple clamp offset?
Posted: 09:24 pm Jan 02 2020
If you can send it back, I'll pay the return shipping.
Posted: 11:17 am Jan 03 2020
by doakley
Funny, you're going to all this trouble to use the rubber cone mounts and I bought aluminum cones because I got tired of the bars getting twisted every time I fell. Each his own I guess. (I know, I should fall less!)
KDXGarage, you are a class act!
Posted: 05:18 pm Jan 03 2020
Thanks, doakley. I must have remembered incorrectly.
Posted: 12:11 am Jan 04 2020
by Owyhee1
No worries kdxgarage, I think it’s the 91 KDX250 upper mount
Posted: 12:16 am Jan 04 2020
by Owyhee1
As far as going to the trouble, it’s also because I have fat bars I’m fond of. I fall as well, but so far don’t remember tweaking the bars, but I have wondered if I should just buy smaller bars and not worry about it. I wasn’t sure If I would notice more vibration or not.
So far...
- C6E5DEE0-C056-4107-9BE6-49DF820897C9.jpeg (141.42 KiB) Viewed 4341 times
Posted: 03:21 am Jan 04 2020
Thank you.
It is looking good!
Posted: 05:32 pm Jan 06 2020
by sarrant
Owyhee1 wrote: ↑12:16 am Jan 04 2020
Then why not just use the regular solid mount fat bar adapters?
https://www.revzilla.com/motorcycle/pro ... lsrc=aw.ds
Posted: 06:16 pm Jan 06 2020
by doakley
What I did, and the adaptors raise the bars slightly, which I like.
