Gear drum
- Molly's 70
Re: Gear drum
It only goes together one way.
- Country: England
Re: Gear drum
Many thanks all that side done if that’s the case fighting with needle roller at minute tried heat tried bearing puller thing will not move soaking it in penetrating oil for 24 hours
- Molly's 70
Re: Gear drum
1 or 2 days of a good penetrating oil can make a big difference. Which needle bearing are you trying to pull out?
- Molly's 70
Re: Gear drum
Agreed. 275 - 300 degrees F. Use gloves & turn the case over on a piece of wood, smack it down to help. Inside bearings may still need the "slide hammer/puller tool" as I call it.
