Snap ring
Re: Snap ring
I always put the flat side to the outside.
Re: Snap ring
I'm with SS. The flat side always facing the same direction that you would slide the gear if you were removing it.
- Country: England
Re: Snap ring
Me being a bit slow here so flat side is towards engine shaped side to front sprocket on all cheers.Wonder if anybody else was aware of this I only realised when Kawasaki dealer informed me
Re: Snap ring
No, flat side facing outward. That way it is a hard square edge against the groove holding on your sprocket.
- Country: England
Re: Snap ring
Got it I think all 4 snap rings on the output shaft have flat side to sprocket
Re: Snap ring
all 4??
- Country: England
Re: Snap ring
Yes rebuilding engine there are 3 inside engine on sprocket shaft
Re: Snap ring
OH. OK. I was thinking outside the engine.
