Alright here's a little update for everyone. Got an email back from Brock today with some good news and some bad news.
The bad:
They are not currently making any kips Valves for the kdx models. The reasoning for this being that they have not been discontinued by kawasaki. Once they've been discontinued and are in a higher demand they may consider producing them.
The good:
They do have a solution for the infamous left valve that seems to fail more often than the right side or the idler gear. Apparently you can use one of their KMX200 valves on the left with a couple modifications. I'm assuming you wouldn't be able to use it on the right since it shares the same space as the idler gear. Here's his word for word on what needs to be done to make it work on the left side:
KDX200 1989 E1 to 1994 E6
Left hand valve can be replaced with KMX200 kips valve with 1mm spacer below and
14.5mm deep by 20mm diam bush above with 6mm hole in center.
Valve must be fitted with dot one to the right of the mark as you look from valve towards rod.
I'm guessing the spacer needs to be circular and 1mm in thickness
. He says if I'd like them to they could make the bush to send out with the valve.
Also a side note he said that in the future it would be a good idea for someone to have a new set laying around that they can use to make replicas off once they're discontinued.
