need engine ID help kh1dx200 EE018098
Posted: 05:38 pm Apr 29 2013
by jreibson
I just picked up a kdx 200 and need to get an intake manifold/carb holder. It's in rough shape and I'm trying to get parts for it. Previous owner said it's a 92 frame with a 98 motor. I found the following number on the motor but can't find any useful information on Google. Does anyone know how to decipher the numbers?
kh1dx200
EE018098
Thanks!
Re: need engine ID help kh1dx200 EE018098
Posted: 06:41 pm Apr 29 2013
by Julien D
The same part will work on either bike anyway, so it really doesn't matter in this case. If you want to share a pic, we can tell you for sure if you have an e motor, h bike, or e/e or h/h or what. FYI, the watercooled 200 only changed once, and that was in 95. So 89-94 are identical, and 95-2006 are identical. 89-94 share a few similar parts with 95+, but have some major differences as well.
Welcome to KDXRIDER!
Posted: 12:28 pm Apr 30 2013
by jreibson
I'll gladly post a pic so I can solve this puzzle. I'll look in the faq to find out how to post pictures.
Thanks!
Posted: 12:50 pm Apr 30 2013
by Julien D
For pics, upload to photobucket or another hosting service, and paste the img code to your post here. Good luck!
Sent from my DROID2 using Tapatalk 2
Posted: 07:23 pm May 01 2013
by jreibson
Posted: 07:42 pm May 01 2013
by rbates9
That is an E bike and motor. E = 89-94.
Posted: 07:49 pm May 01 2013
by jreibson
Thanks very much! The guy I bought it from said it was a 92 bike with a 98 motor. That's not all he lied about. glad I didn't pay much for it.
My current plan is to replace the carb holder/ intake manifold, replace the transmission oil, drain and refill the tank and run it for a few hours to see if it's worth putting any time or money into.
I really appreciate your help figuring this out.
You guys on this forum are impressive.
Posted: 08:25 pm May 01 2013
by Dekon
I don't know if you have it, but I would put the case saver back on it before you take it for a ride.
Posted: 08:38 pm May 01 2013
by jreibson
I'm not sure what you mean by a case saver. I took the counter-shaft sprocket cover off to clean the gunk off the engine. I also removed the rear fender, the guard that sits below the rear fender and protects the shock, the radiator guards and the side panels. What's a case saver?
Posted: 08:43 pm May 01 2013
by rbates9
The case saver is the steel part that should have been behind the plastic sprocket cover. It is there so if the chain breaks it can't get wadded up between the case and the sprocket and break the case.
Posted: 09:33 pm May 01 2013
by bufftester
Looks like there are a couple of healthy exhaust leaks as well, at the cylinder head and the pipe/muffler joint.
Posted: 11:02 am May 02 2013
by jreibson
I'll look for the case guard and put it on if I have it.
As for the exhaust leaks, are there replaceable seals at the cylinder?
I don't know what to do about the pipe/muffler joint leak. Any ideas?
Posted: 02:42 pm May 02 2013
by Dekon
On the pipe there are two o-rings and a copper washer(at least it looks like copper) that goes inside the cylinder flange. For the connection between the pipe and silencer I got a Rocket exhaust pipe to silencer coupling. It is made out of high temperature rubber. I like it better then the stock one because it allows a little flex and seems to lessen vibration.
Posted: 03:25 pm May 02 2013
by bufftester
At the cylinder best thing to do is make sure BOTH springs are present and serviceable, check the two o-rings and gasket. Lots of folks also use hi-temp rtv to seal the flange with good luck. You can also use the rtv at the pipe/silencer junction underneath the rubber connector. The more I look at the pics tho I don't think its a bad leak so much as the bike looks like it has NEVER been bathed. She needs a good steam/pressure wash for sure.
Posted: 03:54 pm May 02 2013
by jreibson
Both springs are there. I'll look for the o-rings and gasket. As for the steam/pressure wash, I didn't want to do that till I got an intake manifold that wasn't dry rotted. I'm going to price parts from my three favorite vendors and place an order tonight.
Posted: 11:36 am May 05 2013
by jreibson
I cleaned more of the grease and grime off the bike yesterday and found out that the chain slider is destroyed and the chain is eating into the swingarm. Is it time for a new swingarm?
Thanks.
![Image](http://i1317.photobucket.com/albums/t623/jreibson/IMG_3727_zps54522c47.jpg)
Posted: 05:05 pm May 06 2013
by bufftester
You can get it repaired, machine shop can weld it and get it looking good. Never seen one eaten up there, usually its on the top side.
Posted: 08:17 pm May 06 2013
by jreibson
That's a great idea. I have a buddy who can weld. Maybe he can fix it for me.
Just looked at your kx/dx hybrid. What a great idea! Can't wait to find out how it handles.
Thanks again for your help.
Posted: 11:17 am May 07 2013
by KarlP
I repaired a swingarm damaged like that by filling the grooves with epoxy putty and putting on a new slider.
Posted: 09:20 pm May 07 2013
by jreibson
Epoxy sounds good. I've had great results with fastSteel and will likely try that.
Thanks.
