looking for pics of WER damper installed
Posted: 07:49 pm Apr 24 2013
by jeeptech1
I just bought a used WER damper and was curious how the rest of you who use one mounted it. I want to try to avoid cutting my number plate if possible. Thanks.
Re: looking for pics of WER damper installed
Posted: 08:18 pm Apr 24 2013
by Dekon
Posted: 09:11 pm Apr 24 2013
by jeeptech1
I've looked at those ones. Looking for more variety. Especially ones with number plates instead of headlights.
Posted: 09:55 pm Apr 24 2013
by Julien D
There's not a great many mounting options, since you can only bolt the damper on in one spot. Between the fender and lower triple. I can't see any way to avoid some cutting of the number plate to clear the arm, unless you have a number plate that you can raise up a bit.
Posted: 10:49 pm Apr 24 2013
by jeeptech1
If I have to cut it I will, it will be worth it having a damper. We will see. I just want to see others with the plate/headlight on for ideas. I have 04-up kx fender and number plate on my bike so there seems to be some room between the forks and rear of the plate. I'll find out how it fits when it gets here! Stoked to get it on!
Posted: 07:43 am Apr 25 2013
by diymirage
what exactly does a steering dampener do anyways?
![Embarassed :oops:](./images/smilies/icon_redface.gif)
Posted: 03:18 pm Apr 25 2013
by Julien D
It's a stabilizer, basically. Prevents the bars from being jerked out of your hands when hitting rocks, roots, etc. They are very effective, assuming the suspension has been set up correctly.
Posted: 05:37 pm Apr 25 2013
by pumpguy
An hydraulic steering damper does for your steering what the hydraulic dampers in your forks and swing arm do for the suspension. Back in the day, bikes had friction steering dampers. These were stationary and movable friction disks, kind of like clutch disks. The friction was adjustable with a big knob that came up through the steering head stem. As Julien said, these make the steering more controlable in rough conditions. I should add "when working properly." I could tell you a story of one that, after hitting a good bump, suddenly went from not working to working all too well, but that would be an OFB.
Posted: 07:11 pm Apr 25 2013
by diymirage
how does the steering feel with one of these installed and properly adjusted?
im having a hard time envisioning it but in my mind it would feel like a dirtbike with the steering stem overtightened
![Shhh :shh:](./images/smilies/eusa_shhh.gif)
Posted: 09:30 pm Apr 25 2013
by royadams
It feels like a steering stem overtighened, but does not have dampening all the way to the steering stops. Some like the wer only dampen one direction and not back to center.
Posted: 09:44 pm Apr 25 2013
by royadams
![Image](http://i1341.photobucket.com/albums/o751/roy3333adams/WP_000358_zps90bcaf76.jpg)
This is a pic of one on my hybrid
Posted: 10:30 pm Apr 25 2013
by jeeptech1
Cool, thanks for the pic! What weight of oil are you running in yours?
Posted: 05:39 am Apr 26 2013
by royadams
5 that's what they recommend for enduro bikes.
Posted: 09:42 pm Apr 26 2013
by jeeptech1
Cool. I'll post pics when I get it done next week.
Posted: 09:24 am Apr 27 2013
by TheJackRabbit
here is one i found online, not my bike. not sure how much this will help
http://www.bryankimsey.com/dirtbikes/KDX/KDX_UFO_1.JPG
Posted: 09:40 pm Apr 29 2013
by holeshot
My WER works very well on my 2004. Here's a photo of mine with a UFO headlight/numberplate slightly altered to fit the stabilizer.
![Image](http://i1012.photobucket.com/albums/af249/dsw509/IMG_0124_zps4e4991e6.jpg)
Posted: 08:46 am May 01 2013
by jeeptech1
Got my damper in the other day. I should have it installed by the weekend and take it for a spin. I'll post picks when I'm done. Thanks for the pics guys.
Posted: 12:04 am May 03 2013
by jeeptech1
Posted: 01:40 pm May 06 2013
by jeeptech1
Went riding this weekend and tested it out. i couldnt really feel it help until i turned it up all the way, but once there it definetly helped keep the wheel straight in the rocks at speed and even saved my neck in a couple cross rutted situations! it didnt hamper being able to turn sharp quickly either. so id say money well spent considering ive got less than 100$ in it. any more $ than that i would just save and get a gpr or scotts.
