Front end all over the place...
- Rick
You're right. I don't care what the others say.
Just 'cuz a thing is unanimous don't make it right!
Well...that's my story...
Yeah...did'ja? You kind'a didn't answer that part..............
Memmer the 'loosen screw, pssst out?, pssst in? part?
'Ya gotta be pacific (sic..just for Inda)!!
- Rick
But...what happened? Air in or out? No air nowhere? No difference in fork action with internal pressure equalized?
If this was already covered, my apologies for missing it.
- Rick
Air out of both when compressed. "Mechanic" has them right now, going through them.....
1996 Suzuki DR 350 $Sold!
2004 DR 650se Road Warrior
2002 DL1000 V-STROM
2002 DL1000 V-STROM
No..not when compressed.
I wanted to know what happened when you loosened the screws as the forks were just SITTING there....was there positive or negative pressure? Did the forks blow or did (do?) they suck?
If Mr. Mechanic checks out this thread, he's not going to like the ""...
Might as well be nice until you know for some otherwise to BE otherwise.
Leave (edit) the offhanded snottiness to the experts.
Like ME!
Well..expert (otherwise known as: has been...drip under pressure) AND a long ways away!
whatizname wrote:Loosen the bleed screw. What happens? Air in? Out? Does the fork act any different afterward?
Like ME!
- Rick
Sorry. I did check them just sitting there, and both of them let out a little air. Didnt affect the way the bike felt. Gotta start somewhere on the snottiness!
2002 DL1000 V-STROM
2002 DL1000 V-STROM
Some pressure build-up is common. My OEM forks did it all the time. I found bleeders to be one'a the best things ever for keeping the OEM forks working well (as they could).
If there was a BIG suck of air..that would give you too much sag..AND hurt the overall compliance of the forks. That was why I asked about it...it could have been what the problem was all along.
But...no...
But...no...
How does that happen with the jam nut...uh...jammed?
Jam nut or no jam nut I think it would take a complete lack of spring preload and some sort of twisting force on the rebound rod to allow it to come free. Don't comprehend how it could happen...... I have to think about this!luke347 wrote:yea check if the cap unscrewed from the rod that happened to me in the race it was horrible it trashed all the threads in the cap take apart asap.
FWIW after 30 seconds of thought: Don't see how the hydraulic pressures within the fork - whether of the rod damper or the cartridge variety - would cause a twisting torque to be applied.
Stock OEM high preload springs with the reported spring wind-up due to screwing on the cap; instead of screw the upper fork tube onto the cap - possibility?? Maybe hummmmm...
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
- krazyinski
sum Times el jam Nut does not get enough jam. not to sweet when it happens.canyncarvr wrote:How does that happen with the jam nut...uh...jammed?
- Rick
Well, im gonna bounce a little. Earlier in the thread, I mentioned that i ordered all new stuff for the swingarm. Parts are in. One question not covered in the book. How far does the swingarm bearings go in? Seems to me, they would be centered, with a cap/spacer on each side. Both of my bearings were offset a little in the swingarm. But, they were pretty wore out, and so were the caps. Logic tells me to press them to the center of the swingarm, but the book doesnt. Tips?????? Thanks.
2002 DL1000 V-STROM
2002 DL1000 V-STROM
I've replaced my bearings..and the replacements were a SINGLE bearing...not two. That said, my remembrance may not be correct.
Don't 'center' them in the swingarm. Well...if that means pushing them TO the center.
Leave as much space between the bearings that you can. 'Centered' in that case could also apply..meaning not IN the center, but EVENLY split, space-wise.
The farther apart the bearings are, the better the load on them will be distributed. Push them in only far enough to give you room for the associated hardware.
Keep in mind that the seal sitting against the bearing is how the bearing is going to be the most protected. Yeah...not a lot in any case, but the better placement, the ..well...better!
ALL of this assumes your 'parts are in' means the OEM type parts...NOT the caged 'double-wide' replacements from, say, PivotWorks. IF the 'double-wide' caged bearing is used..then 'centered' it is!
OkeyDokey?
OkeyDokey?
- Colorado Mike
I thought the book does tell you how far to press the bearings. But, maybe I'm remembering the kid's KX manual. in any case, CC is right , you press them in about 4mm to allow room for the seal, and leaving a space between the bearings.
- Rick
That's not OEM..that's aftermarket. Well..unless OEM changed...and I duobt that.
I don't recall how much 'play' there is in placement..seems there isn't much. I'm saying I don't think you can place that one bearing 10mm from one side and 4mm from the other.
So...center it!
So...center it!
