Page 2 of 2
Re: Welded front sprocket
Posted: 04:06 pm Jul 19 2019
by doakley
Just my $.02 but it would seem prudent to consider an overhaul of the bottom end and all bearings and seals as a minimum. If this is an example of the PO's maintenance you might be better off to get ahead of the game here. Just a thought.
Posted: 08:30 pm Jul 19 2019
Bearing supporting that shaft at a BARE minimum
Posted: 10:11 pm Jul 19 2019
by SS109
KDXGarage wrote: ↑03:51 pm Jul 19 2019
chain tension may have gone awry
That or a sloppy fitting sprocket from the get go or one left on way to long and then becoming sloppy. The counter shaft sprocket will wear just like a clutch basket from being on/off with the throttle only a lot slower.
Posted: 07:02 pm Jul 31 2019
by Strictly Kdx
I would use a die grinder but don’t cut too deep, you can shave it down then give it a hard tap to crack the weld loose but what I’m wondering is maybe it was welded because the spline teeth sheered, this happened to my bike so I welded it a certain way to take it off when I’m ready to replace it.
Posted: 02:54 pm Aug 01 2019
by bufftester
its normal for you to turn the output shaft and have a little play before the input shaft turns. Not changing sprockets and incorrect chain tensioning over a long period can cause this kind of wear. Someone did not believe in pre/post ride maintenance before you got it lol
Posted: 01:58 pm Aug 02 2019
by Parney
Well here is what’s left when I got it off
Posted: 02:00 pm Aug 02 2019
by Parney
What a mess but now
Posted: 02:02 pm Aug 02 2019
by Parney
Looking at getting one of the older air cooled kdx now this is finished hoping for £2000 as they are very rare over here
Posted: 03:41 pm Aug 02 2019
by kdxsully
Parney wrote: ↑01:58 pm Aug 02 2019
That’s crazy. Good luck in finding an air cooled. I love mine.
