Transmission gears
Transmission gears
What year transmission gears will fit in my 01 I been looking but can’t find none in my gear range
Re: Transmission gears
Welcome to kdxrider.
Are you looking for just a few parts or all of it?
1995 - 2006 KDX200 and 1997 - 2005 KDX220R transmissions are the ones to look for if shopping for all the parts. Some 1989 - 1994 KDX200 transmission parts are the exact same part numbers. Check here to match up part numbers:
https://www.partzilla.com/catalog/kawas ... ansmission
I’m looking for the 3rd and 4th main shaft gear if you can help me find a part for a good price or just that 1 or 2 gears it self
Can I just ride my bike on a a chipped gear if it’s not that bad bc I can’t Offord 200 dollars just for all the gears
- Country: thailand
Don't put it back together with chipped gears, if possible find a whole transmission cluster from a kdx220sr as the gear ratios are far superior
Yes you have to spend the money now but you will make some back in resale value on your bike showing a thorough rebuild
Sound good thank you and yea I won’t be selling it I’ll keep it for however long I can
- IMG_0107.png (1.39 MiB) Viewed 279 times
- IMG_0108.png (1.18 MiB) Viewed 279 times
Are thos gonna work
Another question I have is can I swap gears from a 89 into my 01
Is this the only gear you need?
No I’m most likely gonna need all of the gears bc I have more than 1 chipped gear
OK, look for 2 shafts and gears from a 1995 - 2006 then. The shafts don't have the same part number on 1989 - 1994 KDX200.
The 3rd/4th gear set part # 13260-1006 then yes it fits from the e series, same part # and tooth count 15t/17t, the output shaft is also the same part # 13128-1164 so if you find a good complete gear set from the e series it's also good for a spare,3 other gears also cross over between the 2 series if those might be the other gears you need.
https://en.impex-jp.com/catalogs/moto/k ... 91193.html
https://en.impex-jp.com/catalogs/moto/k ... 88958.html
02 KDX220
What do you think are these shot out or still usable
- image.jpg (2.72 MiB) Viewed 103 times
- image.jpg (2.62 MiB) Viewed 103 times
- image.jpg (2.2 MiB) Viewed 103 times
