TAIL/BRAKE bulb
TAIL/BRAKE bulb
Hi, I am trying to figure out what bulb is correct for my89 kdx200. its a 1158 I believe but 6v or12v??? thanks a million in advance
Re: TAIL/BRAKE bulb
It's a 12 volt bulb. I thought it was an 1156 type IIRC.
Re: TAIL/BRAKE bulb
Welcome.
It is the single filament 12 volt.
Re: TAIL/BRAKE bulb
No brake light as standard on 89 E series or later H series KDX. If this is wanted, you'll have to modify bulb socket and fit dual filament bulb, and brake switch(es). Also, std 40 watt lighting coil may not have enough power for the headlight and brake light.
Online searching on this site and elsewhere has much on this subject including rewinding stock coil for more output, and firms like Ricky Stator that offer higher output lighting coils.
Re: TAIL/BRAKE bulb
Yep, stock is just a taillight.
