KLX 140L / KX 80 Fork Swap
B737driver
Post by B737driver »
Well, after a successful KDX/KX fork swap, I am now looking for some direction on the wife's KLX. Recently bought a '98 KX 80, parted it out and kept the forks and triples, along with the front brake assembly. There is a little info over on TT, just thought I'd see if anyone here on the my home turf has any experience with this swap.
Thx,
Don
Live to Fly
Fly to Live
rbates9
Post by rbates9 »
I assume the wheel size and the fork length is about the same? Then it should be about the same as the KDX/KX swap. Do a write up and let us know.
smokehouseman
Re: KLX 140L / KX 80 Fork Swap
Post by smokehouseman »
I did this on my sons DRZ125L I used RM85 forks they were a direct swap. you just need to move the forks up in the triple trees a bit to get the right geometry. You will also need the front axle from the forks your going to use. A huge improvement.
