I need to replace the front caliper pistons on my 1993 KDX200 and cannot find them anywhere. The 1993 Suzuki RM250 front caliper looks exactly the same, is there a cross reference for this part from other manufacturers or a non oem part?
Help!
Sean
1993 KDX200 front caliper pistons needed
Re: 1993 KDX200 front caliper pistons needed
I’d imagine the KX models used the same calipers. KDXG might know for sure.
Welcome to kdxrider.net. Have you considered buying a used caliper and using it?
This Kawasaki 43048-1057 PISTON-CALIPER Not Available fits the following models and components:
Kawasaki Motorcycle 1989 KX250 - KX250-G1 Front Brake
Kawasaki Motorcycle 1989 KX125 - KX125-G1 Front Brake
Kawasaki Motorcycle 1991 KDX250 - KDX250-D1 Front Brake
Kawasaki Motorcycle 1992 KDX250 - KDX250-D2 Front Brake
Kawasaki Motorcycle 1993 KDX250 - KDX250-D3 Front Brake
Kawasaki Motorcycle 1994 KDX250 - KDX250-D4 Front Brake
Kawasaki Motorcycle 1992 KX500 - KX500-E4 Front Brake(KX500-E4/E5)
Kawasaki Motorcycle 1990 KX250 - KX250-H1 FRONT CALIPER
Kawasaki Motorcycle 1991 KX250 - KX250-H2 FRONT CALIPER
Kawasaki Motorcycle 1991 KX500 - KX500-E3 FRONT CALIPER
Kawasaki Motorcycle 1990 KX125 - KX125-H1 FRONT CALIPER
Kawasaki Motorcycle 1991 KX125 - KX125-H2 FRONT CALIPER
Kawasaki Motorcycle 1989 KX500 - KX500-E1 FRONT CALIPER
Kawasaki Motorcycle 1990 KX500 - KX500-E2 FRONT CALIPER
Kawasaki Motorcycle 1993 KDX200 - KDX200-E5 Front Caliper(KDX200-E5/E6)
Kawasaki Motorcycle 1994 KDX200 - KDX200-E6 Front Caliper(KDX200-E5/E6)
Thanks KDXG that is just the info I needed! Found a source immediately. Whew!
You're welcome. I think we are lucky on the stuff that happens to also fit a KX also.
