GOT WOODS? wrote:This is a response to the posting above, I can't seem to get the hang of the quoting thing......
/quote]So the rectifier just goes in line in the wiring?
That's how I did it. Ground and lighting wire into the rectifier, pixie dust comes out! I mounted it on the down tube.
Conveniently The front end is off, so here's a picture.
Note: the stock regulator is not hooked up.
[/quote]
[/quote]
HELP!
On my 2003 220 I did the lighting kit from RMATV and then I added an LED headlight after modifying the bulb plug from a 2 wire to a 3 wire to get the hi/lo beams. I bought a rectifier that looks exactly like the one in the picture above but the instructions were useless (to me anyway...) so I did not hook it up. I hooked the LED headlight up to the bikes existing lighting circuit, not the new battery-driven horn/directional/tailight circuit. The led will come on when the bike starts but it flickers at idle, then goes out completely when I rev the bike off idle. It looks like I have to hook up the rectifier but can someone explain what wires go where?
The instructions say the following:
HOW TO WIRE IT:
-Red: "+" Output, to (battery +)
-Green: "-", to (battery -)
-Yellow, Pink: AC input, connect to magneto coil
So I'm guessing that I want to hook the wires up as follows:
-The red I hook up to the power input wire on the new hi/lo beam switch on the handlebars. This would then put power out to either the hi or lo beam at the LED depending on the switch position.
-The green to the LED's ground wire- but do I also connect this wire back to what was the original stock headlight's ground wire which I am currently using?
-The yellow and pink wires, I am assuming one of them has to connect to the original headlight's incoming power wire to energize the circuit, but where does the other wire connect to? Do I connect it to the original ground wire? Or do I have to go back to the stator and I'll find two wires there to connect these two wires to?
This is the unit I bought:
I noted that the fellow above said that his stock regulator is not hooked up. Do I need to disconnect mine? And why did the stock regulator not take care of this issue?
Thanks in advance for any help![/quote]
Let's build an understanding here:
* The stock system generates AC, alternating current.
* The LED light needs DC, direct current.
* The stock regulator regulates how much voltage is going to the light.
* Your light flickers at idle because it's on on every other cycle when the AC is going the correct direction. You can destroy LEDs running AC through them. Some handle it, some stop working.
* The rectifier converts AC to DC. In order to do this, you feed the two AC inputs into it(to the yellow and pink) and use the rectified(converted to DC) hot and ground wires coming out of it to power and ground your lights.
* The unit you got is both a regulator and a rectifier. It replaces the stock regulator, but also rectifies the current into DC.
Yes you do want to disconnect your stock regulator as you're replacing it with the regulator/rectifier. They can produce some weird results if both hooked up. There's a voltage drop in the process of rectifying, so the regulator adjusts it AFTER the rectifier.
As far as I understand, this is how it all works. You'll still get a little flicker at idle unless you add a small battery or capacitor to smooth out the voltage.
