Kdx 200 E series crankcase compatibility
This is for E series info...
Re: Kdx 200 E series crankcase compatibility
Post by Molly's 70 » 03:06 am Oct 30 2018
Jason wrote:I think there are steel inserts in the aluminum that are bearing holders. It looked like a little rust on that.
It looks that way to me also.
Martin, I want you to find a magnet & check if they are in fact, steel inserts. Aluminum in not magnetic.
Martin-vereert
Country: Argentina
Post by Martin-vereert » 08:51 am Oct 30 2018
Oh! Sorry didnt realiced why you where asking that. It's steel indeed, it has 3 small pieces that goes all the way trough the case you can see them in one of the pictures.
I was thinking on giving it a welding point (probably that's not how it's called in english) where the crack starts so that i dont touch that metal thing.
Im worried it's going to fall off when the case heats up.
Post by Molly's 70 » 02:03 pm Oct 30 2018
Ok, So we know the insert is in fact steel. The insert did not appear to me, to go all the way though the case. It looks like the steel insert is pressed in from the inside of the case. You will definitely want to weld the outside of the case as I stated earlier. If the insert falls out do to heat from welding, you will have to press it back in. Let's get the case welded first, then worry about the insert. It may not fall out.
Aluminum & steel will NOT weld together. It would be like trying to mix oil & water. It just doesn't work. You will see a "greenish" color under the hood if try to weld them, just before everything goes to crap. Ask me how I know.
Just for future reference:
Aluminum corrodes white = aluminum oxide.
steel corrodes orange = iron oxide.
This is what made me think we have 2 different metals involved here.
Martin-vereert
Country: Argentina
Post by Martin-vereert » 08:34 pm Oct 30 2018
Awesome! Cant wait to give it a try, need that argon first tho and of course quite a bit of practice.
You are of so much help Molly, thank you.
Dont know when i will be able to get that refill but i will post as soon as i start welding.
Post by Molly's 70 » 02:07 pm Oct 31 2018
I'll be here. Post pictures of your welding samples if you feel comfortable doing so. I will tell you all the tips & tricks I know. Questions & pictures will help me, to help you. I'll be ready when you are.
Martin-vereert
Country: Argentina
Post by Martin-vereert » 08:43 pm Nov 27 2018
Hi everyone!
Im really sorry for not replying back in so long after all the help i got. I thought the web was down or something.
I got totally overwhelmed by the amount of things the bike had wrong, went back and forth on the idea of selling it by parts. Finally after reading so many good things about the bike i decided on giving it a shot and repairing it.
The case this post was about got welded by a friend, i feel bad because of the time i made Molly waste on explanaitions. I learned a bunch on the process tho' and the job turned out great!
Summing-up. The bike started for the first time today, so happy. Im so gratefull for all the help i recibed, especially from Molly.
I will make sure to get a decal for the bike with kdxrider.net on it!
Cheers!
Martin.
Post by KDXGarage » 11:14 pm Nov 27 2018
Congratulations on getting it going!
kdxrider.net forum member doakley participating in National Enduro series:
(current class standing, 5th!)
viewtopic.php?f=136&t=23217&sid=e6a86d8 ... 9&start=40
Post by Molly's 70 » 04:33 am Nov 28 2018
Excellent job Martin! I don't feel that I wasted any time. Glad you got it running.
