Okay.
Okay.
I'm having an issue with lurching forward(body shifting forward) on my 03 yz250 when ever I use it for trail riding, and I didn't used to do this on the KDX. I've only been riding bikes for a year now, and I feel that I'm kicking ass and taking names but this is getting kind of annoying especially when you're in the middle of a rocky trail. Any advice would be great.
Try higher bars, heavier flywheel and lower overall gear ratio.
Powerwise, 2 stroke MX bikes tend to 'sign off' earlier when the RPMS drop than more mildly tuned trail bikes, creating a power 'Void' so to speak. On the way down, their either off or on with very little usable gray area in between.
that sudden abrupt loss of power causes a whole shitload of changes- to the geometry of the bike, and how a rider responds.
If I can't do it, I'm sure someone else can!
Okay I get it, when I let off it practically shuts off, so in a way its engine braking(Weird). Power delivery on this bike is near perfect, climbs everything and rides trails great. I'm already planning on a 52t sprocket to have a better power delivery(14/50 currently). I'm running Pro Taper Contour bars with a half inch riser fat bar adapter, so there's no problem there. Other than that one set back I don't regret getting this bike.
- gsa102
- gsa102
Just comparing it to my 450F which has massive engine braking...
Conventional wisdom says to grip with your knees, but I can't quite figure that out. But at 6'1", I am a little taller than what they consider to be the average rider.
96 KDX 200, 09 YZ 250
- kawagumby
On 2 stokes or 4 strokes I always disengage the clutch when decellerating regardless of speed. That allows me to keep the revs right where I want them, and I can use the clutch to act like a lower gear too while actually being in a higher gear. You get less rear wheel bounce too as you have more control modulating the rear brake than using engine braking (even with a 2strk). When in really tight stuff the hand is always on the clutch - and varying the engagement is key for smooth riding. On more wide-open trails you can come into a turn a gear high that way and really boogie out.
I will use 4strk compression braking in some situations, but not in tight stuff.
Using that method will eliminate stalls and down hill rear-end swaps too. After a while it will become second-nature.
