kdx in a kx frame
KR90
kdx in a kx frame
Post by KR90 »
What are the advantages to dropping a KDX motor into a KX frame? and if so what years work with a 2003 220?
3j3j3j
Re: kdx in a kx frame
Post by 3j3j3j »
Lighter weight frame, with better handling amd better suspension. Any year kx will work but I am sure some years would be easier than others.
diymirage
Post by diymirage »
mostly the better handling and suspension though (and, if you are into that kind of thing, a more modern look)
I seem to remember one of our member making a KX 125 hybrid and weighing that, it only weighed less then 10 pounds less than a stock KDX
-1997 KDX 220 project bike
G22inSC
Post by G22inSC »
Is the suspension and handling that much better than a KDX with KX forks? I just don't see that much difference between the frames.
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
KarlP
Post by KarlP »
Yes.
I did the xr400 springs upgrade, then the KX forks upgrade, and finally built a KDX powered CR250. There is no comparison.
To be fair though, the KDX was better for just plunking around
'08 KTM200xc
KX100 for the boy
It's really apples and oranges. The KDX is a trail bike, whereas the KX is an MX bike. In certain situations, a properly suspended and tuned KDX will have its advantage. In others, the lighter and more nimble MX chassis will have its own advantages. When deciding if an MX hybrid is the build for you, it's important to consider what you spend most of your time doing with the bike, and what you expect from it.
adam728
kdx in a kx frame
Post by adam728 »
And don't forget the big difference in ergonomics. KX is much slimmer, with a flatter seat-to-tank transition.
Correct. The kdx is more of a sit IN, and the kx is more of a sit ON.
newbbewb
Post by newbbewb »
Apples to oranges is right. In some places i love my hybrid, in others i hate it and look down on it. i've still been unable to find a bike thats all around as good as a kdx in the tight trails. Once the trails open up a bit the hybrid is just unbeatable. I would liken the hybrid as a quiver weapon.
93 kdx200-Highly modified
89 kx125/kdx200E engine
Buelldustin@gmail.com
Absolutely. I want a hybrid, but am not willing to give up the comfort of my E bike. It's like a tractor powered couch, lol.
G22inSC
Post by G22inSC »
How do the mid 90's to 98 KX frame compare to the H series KDX? Would a hybrid off one of those frames be similar to a late model hybrid or not really worth the effort for such a little gain over the stock KDX?
'08 Kaw KX65 (Sold)
Gallery
Probably not much gain, but would be a fun build. I've got a 93 kx125 roller in the shed, if I ever happen across an H series motor / donor bike for it, I will find out .
6 Riders
Post by 6 Riders »
The biggest gain/loss that you will realize is the longer rake of the KX. One of the reasons that the KDX is so good in tight woods, the short rake. But the hindrance to the short rake is that it (the KDX) doesn't land jumps as well as a KX.
IMO that would be the largest gain/loss (as apposed to just swapping forks), doing the DX/X hybrid. So if you want to race a KDX on a "track" that has lots of big jumps, the Hybrid would be Ideal. But then again, if you ride trails a lot, you loose the ability to ride in circles around a tree.
19Delta
Post by 19Delta »
Which is the best bike for a beginner, a KDX with better forks, or a KDX/KX hybrid? I will use it to play around on, and right tight trails and enduro's. No motocross racing or jumping at all.
Sent from my SM-G900V using Tapatalk
kx200
kdx in a kx frame
Post by kx200 »
for what its worth the 2003-2005 chassis is the easy one to convert. It can use the stock KDX pipe.
