48 T sprocket, chain length.
Posted: 02:21 pm Apr 23 2018
by pumpguy
I have a spare rear wheel for my H series KDX 200, and am thinking of fitting a 48 tooth sprocket. The CS sprocket is standard 13 tooth and the chain is standard 108 links.
Using an online chain length calculator, it says the center distance using the 108 link chain will decrease by .172", or a little less than 3/16", compared to the standard 47 tooth sprocket.
I could measure the amount of adjustment I have left, but the bike is not where I can get to it right now.
Does anyone know from their personal experience if I can use a 48 tooth sprocket with the standard 108 link chain and 13 T CS?
Posted: 06:01 pm Apr 23 2018
by SS109
Hmm, could be close to being a little tight but would probably be ok. I'm running 13/48 with a 110 link chain. Snail adjuster when new was at 3 and was just recently adjusted to 3.5 after 6 years. I do tend to run my chains a little on the loose side though.
Posted: 07:46 pm Apr 23 2018
by pumpguy
With the snails at 3, you have quite a bit of rear adjustment left. Combined that with a 110 link chain, this doesn't sound too encouraging for what I was hoping to do. My 108 link O ring chain is in very good condition, and I really don't want to buy a longer one just to go up one tooth on the rear sprocket.
Maybe I can find an extra link set and another master link to come up with the needed extra length.
Thanks for your reply. I really appreciate it.
Posted: 01:17 am Apr 24 2018
by SS109
How much adjustment do you have with the 13/47 and 108 link chain?
Posted: 10:20 am Apr 24 2018
by pumpguy
My snails are at 5.
Posted: 03:39 pm Apr 24 2018
by SS109
You think the adjustment wouldn't be enough? I think it would be real close but just might work.
Posted: 10:11 am Apr 25 2018
by pumpguy
On another site, RMATV I think, there is a post saying a 48 T sprocket will work with standard 108 link chain and 13 T CS sprocket.
Guess I will just have to put the sprocket on and see for myself.
Thanks again.
Posted: 08:30 pm Apr 25 2018
by SS109
Your welcome! Hope it works. Please update us on how it turns out.
Posted: 06:14 am Apr 26 2018
by ohgood
pumpguy wrote:I have a spare rear wheel for my H series KDX 200, and am thinking of fitting a 48 tooth sprocket. The CS sprocket is standard 13 tooth and the chain is standard 108 links.
I have 15/48 on my h , you'll be fine.
Posted: 06:15 am Apr 26 2018
by ohgood
SS109 wrote:How much adjustment do you have with the 13/47 and 108 link chain?
15-48 is set on about position 2 , chain has very little wear on it, new sprockets
Posted: 06:15 pm Apr 26 2018
by SS109
With a link 108 chain?
Posted: 02:27 pm May 19 2018
by pumpguy
Good news!
With a new 48 T rear sprocket, the fit is just fine. Snails are now set at 3. No other changes were made.
Thanks again to all who replied. Hope this helps others considering this change.
Re: 48 T sprocket, chain length.
Posted: 08:48 pm Jan 22 2019
by Vossman
Have you guys found any issues with the chain guide when going to a bigger sprocket?
