Installing Racetech 3750 springs on a 1992 KDX200
Posted: 04:21 pm Mar 11 2022
Hey guys,
Just picked up my racetech 3750k springs for my 92 kdx200. Im looking to use the long spring plus the 2 little springs to acheive the coveted .40 spring rate for my skinny ass.
What order when installing do the little springs go (or does it matter), where do the washers go (between little springs or spacers), and what fork oil height level do you use (OEM spec or altered)?
This is what im thinking for the install, let me know if i have it right if youve installed the 3750k kit. Im listing items as i put them in the tube
1. Long .46 spring
2. racetech Washer
3. Little spring #1
4. ractech washer
5. little spring #2
6. OEM spring cap/washer thingy
7. custom spacer cut for 5mm or so preload
Racetechs instructions also mention putting washers on both sides of the spacer, but i think the oem steel spacer rides between the cap and the OEM spring cap washer thing. It looks like the OEM shock diagram confirms this.
Thanks! Stoked to get my rear linkage rebuild too and hit the trails again
1. Long .46 spring
2. racetech Washer
3. Little spring #1
4. ractech washer
5. little spring #2
