Im about to pull our my 2000 kx125 forks for seals.
I keep reading about removing the restrictive barrier, can anybody point me to where it is and what to do with it?
2000 KX125 forks tuning, restrictive barrier?
Re: 2000 KX125 forks tuning, restrictive barrier?
The white plastic ring
http://www.kdxrider.net/forums/viewtopi ... 86&t=22433
The picture with the forks disassembled has the white plastic ring in the lower left corner. Removing that is easy and it disables the bladder. I removed the bladders also which are the black rubber tubes also in that picture. Jason would know whether removing the white ring is all that needed or removing the bladders helps also. Servicing them in the future will be easier (cleaner anyway) without the bladders.
Yeah, either way they say.
I put some 2000 KX125 forks on my friends KDX with an Emig Racing stem.
I pulled the bladders, but read later one could just do the white plastic ring.
Oil level and quantity are affected by pulling the bladders.
Ah righto. My bladders are long gone. I was reading it was something on the rebound valve that needed to be ground into a petal shape.
I haven't read that.
I have since worked out the barrier is the white ring. Or you just put a washer under the spring so it doesnt cover the transfer ports.
