Gotanubike wrote:The other thing was the tapered steel cups that the bearings are seated in/on. The All-Balls bearing kit includes the tapered bearing + seal for top and bottom but not the cups? Have to wait until the kit arrives
My kit has everything needed to replace the bearings.
6riders wrote:What is the length of the KDX stem that sticks out above the triple clamp?
Like this?
(Numbers are likely not 100% accurate)
Yes like that. Looks to me and someone else was posting about what they had to do for this swap. The upper part of the clamp, where the bearing sits, needs to be milled down a bit as well as the inner part of the bottom of the tree, where the stem seats, in order to get the length needed for the KDX neck.
OK, I just measured the KDX stem sitting in a 95 RM clamp and get 24.6cm, I think that is 246mm. So I could be wrong.
