Rear Shock Piston Ring
Posted: 12:13 pm Jan 01 2019
by firsthere
There is a little play in the shock body (with new rod guide) anyone know if these are available?
Re: Rear Shock Piston Ring
Posted: 01:48 pm Jan 01 2019
by bufftester
They are usually included in shock rebuild kits which can be found on most online distributors sites. I have seen them separately in a couple places, but have no experience in ordering them separately.
Posted: 04:25 pm Jan 01 2019
Technical Touch has the piston band and o-ring. You can get them online or at a local dealer through Tucker or other distributor. 44 mm band
bufftester, there is no KDX kit.
Posted: 11:51 pm Jan 01 2019
by bufftester
Yeah, that's why I said usually in a kit, I have a KX shock and there are kits for it. Just found them at
Pro-Tec as well.
Posted: 01:09 am Jan 02 2019
https://www.ebay.com/itm/KYB-Shock-Pist ... :rk:1:pf:0
DO NOT forget to buy a new o-ring. When you look at the old one, it will amaze you. :-)
https://www.ebay.com/itm/Technical-Touc ... :rk:1:pf:0
Look at the Technical Touch part numbers, then go shopping for those.
120214400101
120224400101
There is just one o-ring behind the piston band on our 89+ KDX shocks.
Posted: 12:08 pm Jan 02 2019
by firsthere
Wow, great information I didn't recall even seeing an o-ring on the piston. Guess I would have found it when cutting the ring off though. What is the best method to install a new one? Is a special tool needed?
Re: Rear Shock Piston Ring - Install
Posted: 11:41 am May 30 2022
by billie_morini
Many times after a shock piston ring is installed onto the piston, the ring must be compressed (shrunken) to correctly function. Home mechanics will tightly wrap the ring with stetched electrical tape. The average wrap quantity is 20. A few home mechanics even place the wrapped piston in a freezer.
What about this idea? I'm thinking about 3 to 4 wraps with electrical tape with a tightened hose clamp placed over the tape.
Posted: 08:44 pm May 30 2022
I'm a 15 to 20 wraps inside out kind of guy.
Congratulations to anyone out there that can afford to have a custom made band sizing kit of tools for 44 mm bands.
Posted: 08:22 pm Jun 08 2022
by billie_morini
I bought two KYB 44 mm shock piston o-rings & two bands (rings) in June 2022 from Pro-Tec Racing in Murietta, CA. Web address is
https://pro-tec.us/
Oh, I used an 0.005 inch (0.127 mm) feeler gauge to slip the band edge over the piston. Kinda like a tire spoon on wheel rim. Lots of shock oil, too. Worked well for me.
