rear shock service-200 -2003
seeking data for rear shock service ,,,primarily oil and gas specifications for reassembly......cheers
pain is inevitable,,,,,,,suffering is optional.
kdx 200-2003
klx 450r-2009
ktm 625 sxc-06
flhrc 2011
kdx 200-2003
klx 450r-2009
ktm 625 sxc-06
flhrc 2011
- OLHILLBILLY
Manual says.. Oil fill to "about 60mm" from the gas resorvoir open end (shock upside down, pouring oil into the gas resorvoir). Then instal the Nitrogen bladder. Fill the shock body until the level is about 52mm from the shock body end.
After everything is together, fill the nitrogen bladder to 7psi, check for leaks. No leaks, fill it to 142psi, and your good to go.
I just took mine to the shop. Think it cost me $25 plus oil, and has worked great ever since.
2004 KDX 200.. Coupla mods
2009 KX250F.. Track Star
good on ya mate.....much oblidged..........cheersOLHILLBILLY wrote:Manual says.. Oil fill to "about 60mm" from the gas resorvoir open end (shock upside down, pouring oil into the gas resorvoir). Then instal the Nitrogen bladder. Fill the shock body until the level is about 52mm from the shock body end.
kdx 200-2003
klx 450r-2009
ktm 625 sxc-06
flhrc 2011
kdx 200-2003
klx 450r-2009
ktm 625 sxc-06
flhrc 2011
