oil is a little milky
frankenschwinn
Post by frankenschwinn »
So the last two oil changes have been Shell Rotella T as opposed to ATF type f. Probably not related but anyway. The last two changes have been a little milky. I assume this means I have a leaky water pump shaft seal? I have not lost enough water to be able to tell.
Is that seal in the outer case? Figured I would change when installing revloc and clutch actuator seal.
I have a manual...
KDXsg
Post by KDXsg »
yes, you might have a leak at the water pump seal. that is call a mechanical seal if i am not wrong. it comes as a complete set that has a spring kind of seal. check also the bottom of the water pump if any coolant leak from the litte hole below.
A true KDX customizer!!
jbowens2401
Post by jbowens2401 »
rotella has always come out a little milky looking in all the bikes i've used it in
Has thanked: 5 times
Been thanked: 12 times
if it's milky as in milkshake, yes, the seal around the water pump impeller has failed. Very common. Make sure you replace the bearing it rides on while you're in there, and check the shaft for wear where it contacts the seal.
