Uprating the generator?
moto_psycho
Post by moto_psycho »
Any tried and tested way you guys have done this?
gregp
Post by gregp »
There used to be some 60 or 70 watt coils available, I think, and Baja Designs will rewind your stock stator to power their dual sport kit. I was able to power their dual sport kit by using LED bulbs in the directionals and tail light, and a Tusk "Blue" 35w bulb in the headlight. It all works fine on the stock stator (no battery).
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
Inda was working on dat awhile back
I rewound my stock stator with good results.
gregp
Post by gregp »
That is interesting, Nick. Can you tell us what was involved in that process - like, what gauge wire you used, how many wraps, and where you obtained it? I presume that the wire can be purchased at Radio Shack, but it has to be coated, correct?
I would like to be able to power a 55-60w headlight...
Check my build thread here or on thumpertalk. Can't remember off the top of my head but I believe it was 17-ga coated magnet wire.
TWMOODY
Post by TWMOODY »
gregp wrote:That is interesting, Nick. Can you tell us what was involved in that process - like, what gauge wire you used, how many wraps, and where you obtained it? I presume that the wire can be purchased at Radio Shack, but it has to be coated, correct?
You can buy the wire you want at any electrical motor shop.
I rewound one portion of a stator many years ago when I was
poor and could not afford 500 bucks for the stator/flywheel assy.
I bought a spool of coated wire, put a dowel rod through the center
and put it between 2 chairs in my kitchen. I fed the wire through a
hard plastic straw (as a feeder) and wound it up.
I took quite a while and when I was done I put a epoxy coating on
the out side.
It worked fine for the 2-3 years that I owned the bike.
That was on a late 70's XT500.
gregp
Post by gregp »
Do you have any idea what gauge wire you used? There is a formula to calculate how many watts you can get, but the gauge of the wire, and the number of wraps is critical to the calculation - I think...
moto_psycho
I have a couple spools of that 17 ga. coated wire.... I never had to try it yet.... shouldn't be rocket surgery...
