Stators
- Cturbo
Stators
I replaced the original stator assembly of my 1992 KDX with a stator from a 2005 model. I know the part # are different but they look exactly the same except for the timing marks. I am missing something ?
1992 KDX 200
2004 KLX 110
2006 SMR 510
2004 KLX 110
2006 SMR 510
- Has thanked: 13 times
- Been thanked: 21 times
Well, does it work? If so, does it light everything up like it should?
- Cturbo
Bob H
Re: Stators
Uh, say what?Bob H wrote:I ended up witha kdx500 lighting coil-bolted right up.
Bob H
Re: Stators
SS109 wrote:Uh, say what?Bob H wrote:I ended up witha kdx500 lighting coil-bolted right up.
oopss... KX500, not KDX.. 87-89. Thanks. It was pretty big - had some concerns if it would fit under the flywheel - but it did and works great.
However, on edit with the part number - here is what I found:
http://www.powersportsplus.com/parts/de ... -1279.html
Indicating it was a KDX-200/220. I have an 89. Ebay said it was both - which we all know is perfect... :)
Bottom line, it was physically bigger than the one I had before. So KDX-200/220, possibly a KX500? More likely the KDX though.
- fuzzy
Re: Stators
I'd want to put a dial indicator through the plug hole to check your timing....Then re-mark.
Bob H
Re: Stators
I thought the three tic marks on the frame the coils bolt to set the timing - I have it still in the middle mark. The frame was identical to the existing one. That being said - I also changed to the 607 reeds at the same time - and my jetting is off - but so is top end power. Maybe worth a check...
