Fuel tank threads for shroud covers
turtle
Post by turtle »
I took the shrouds off my bike to fix a cooling hose leak and it seems one of the brass (?) threaded "inserts" on my fuel tank is slightly buggered up. Unfortunately it doesn't look like they are serviceable.
So before I screw it up by forcing the screw in, I thought I would run a tap in there to clean up the threads. Is this the best idea or is there something else I should do? I don't want to be faced with having to replace anything.
Is there anything else to do, besides being careful, to keep these threads in good shape ... removing shrouds is pretty common for lots of different work that has to be done on the bike!
Bill
Central IL
2004 KDX220R
2011 Triumph Tiger 1050 SE
Has thanked: 6 times
Running a tap is the only fix short of replacing the tank. In the future, always thread the bolts in by hand using a socket on a short extension (don't use the ratchet!) to start them and thread them down until you need to torque them.
I had the same issue and after taping the hole I used a little bit longer bolt to get down a little further into the threads in the brass. I think I swaped the bolt with the right side seat bolt and it had about 2 more threads on it. If you do try a longer bolt make sure it dose not bottom out and poke a hole in the tank.
KDX4ID
Post by KDX4ID »
Fuel tank bolts require "the touch".
CURRENT FLEET
2008 KTM 990 Adventure...Alaska here I come!
2010 KTM 300 XCW... stop me before I buy again!
2005 KDX220... single track sweetie
2007 KTM 450 EXC... my baby
2008 KTM Superduke... Canyon Carver
1996 Honda 650L... GONE but not forgotten
http://www.friendsoftruckeetrails.org
