Bar dampeners, help!
99sr220
Post by 99sr220 »
Those little rubber cones (dampeners?)that connect the bars to the triple clamp are not really working, they have gone in so far that tightening the nuts just warps the washers and the bars twist with the slightest know.
I don't have time to chase up a new set, is there anything I can do quickly to remedy the situation? I was thinking about adding some other washers to strengthen the original ones which seem a bit weak.
Any suggestions? I'm going riding tomorrow and need a quick fix.
ihatefalling
Post by ihatefalling »
I dont know what you could do. Sounds like they need to be replaced :oops:
2005 KDX 220
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
You might be able to find those expandable rubber plugs for plumbing at the hardware store that are that size that would work.
frankenschwinn
Post by frankenschwinn »
Kawasaki Dealer?
Ipaman
Post by Ipaman »
I don't know about his, but the dealers around here don't carry much in stock.
99sr220
Post by 99sr220 »
Ipaman wrote:I don't know about his, but the dealers around here don't carry much in stock.
Same here
Mildew
Post by Mildew »
This isn't going to help you tonight but the Scott's Performance bar mount cones are much better than stock. I crash a lot and they hold up really well.
http://www.scottsperformance.com/produc ... artType=87
2004 KDX 220
2002 YZ 125
Mr. Wibbens
Post by Mr. Wibbens »
I've never seen these cones (except for pics) but I'd think a guy could go to the hardware store and buy some rubber bumpers. And a little bit of work with a sander or a dremel I'd think you could make something that would work
Or make em out of uhmw and never worry about it again
99sr220
Post by 99sr220 »
Mildew wrote:This isn't going to help you tonight but the Scott's Performance bar mount cones are much better than stock. I crash a lot and they hold up really well.
That's useful, I actually replaced the cones recently with some that appeared new, however it seems the rubber had weakened with age.
One of my farovite things about swapping to the KLX forks was that the bar clamps are one piece with the top triple. No more tweaked bars!
bmiller
Post by bmiller »
These are amazing,.. 100 times better than the stock rubber.
muddertrucker
Post by muddertrucker »
I had a friend make me a set completely out of aluminum. Didn't feel any more vibration than usual.
Gallery!
Mr. Wibbens
My KX triples did not come with mounts
Got some mounts today and they did not come with cones
So I made some out of uhmw tonight
I won't really know if they work until I get the forks done
gregp
Post by gregp »
I would like to make some as well. Do you happen to recall the dimensions? OAL? Taper angle?
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
Mr. Wibbens
I just shaped them until they fit :wink:
Mr. Wibbens
Cut em out with a hole saw on my drill press and figured out a way to put em on an axle and spun em down on the bench grinder
99sr220
Post by 99sr220 »
The shop didn't have any from Kawa, so I bought a pair for a CR. The owner told me customers said they worked better. I don't know if that's true, but they've held up fine for several rides (and a couple of small spills).
OLHILLBILLY
Post by OLHILLBILLY »
I used the Scotts cones in mine too. Work great, no more crooked bars. :grin:
2004 KDX 200.. Coupla mods
2009 KX250F.. Track Star
