Fuel & oil Ratios for diiferent Two strokes you have
Posted: 10:48 am Sep 20 2010
by gtoron
This is not a KDX question but was wondering everyones thoughts.
I have four different types of lawn/garden tools that uses 32:1, 40:1 & 50:1
pre mix ratios. Echo weed wacker & Chainsaw,Lawnboy mower, Craftsman Blower.
Was wondering if I could use one pre-mix across the board for all these different tools as it would be a lot easier that mixing for each machine.
I currently run Mobile 2stroke synth oil or Amsoil Interceptor.
Posted: 11:14 am Sep 20 2010
by David_L6
I have an Echo weed trimmer, a chainsaw, and three 2 stroke motorcycles. I use the same gas in all of them: AV gas + Klotz oil @ 32:1.
Posted: 11:41 am Sep 20 2010
by Tedh98
32:1 in all my 2 stroke engines, doesn't matter what they are in.
Posted: 12:21 pm Sep 20 2010
by Julien D
Agreed. run them all at 32:1 on whatever oil you like to use.
Posted: 02:42 pm Sep 20 2010
by KarlP
My saw and trimmer run much better on the motorcycle mix than they did on the cheap crap.
I was visiting my Dad and he had run out of his cheap crap so we ran some of my matorcycle mix in his saw. Much better...
Posted: 03:20 pm Sep 20 2010
by gregp
Your smaller bore, higher revving engines will require more oil than your larger bore machines. 32:1 should suit all of them. Chain saws are notorious for siezing with fuel/oil mixtures leaner than that.
Oil/ Gas Ratio
Posted: 11:16 am Sep 22 2010
by Montips
I've been running Golden Spectro @ 50:1 for everything two stroke since the early 70's with zero problems.
Posted: 11:18 am Sep 22 2010
by Indawoods
50:1 Amsoil Interceptor in EVERYTHING! Even my 4 stroke mower... everything likes it....
Posted: 12:43 pm Sep 24 2010
by Little Jeff
40:1 with Mobil 1 synthetic premix if you can find it.
Little Jeff
Posted: 10:01 pm Sep 24 2010
by Julien D
i been running the interceptor lately too. Been really happy with it. I mix 40:1 though.
Posted: 06:57 am Sep 25 2010
by Griffbones
Been using Amsoil Dominator @ 40:1 for a few years now, seems to work well for me.
Posted: 12:20 pm Oct 12 2010
by lemmy
I run 44:1 in the KDX. The Echo blower and Echo weedeater call for 64:1. The Lawnboy lawnmower is 32:1.
I have noticed many people run less oil (the KDX spec is 32:1, but many run 50:1). How do you know how low you can go? I would like to just make 50:1 and run that in the Echo stuff and the KDX and just keep the lawnboy on 32:1 cheap lawnboy oil (it has been running great for 10 years on that and it is cheap).
Posted: 12:42 pm Oct 12 2010
by Indawoods
When these things came out... there was no high quality synthetic oil. Now that it is available... the oil manufacturers started out calling for 100:1
People weren't comfortable with that... so they started suggesting 50:1 ... people could almost buy that ratio.
Lawnboy and other 2 stroke lawn motor manufacturers don't think that you are going to run high quality synthetic so that's why they suggest such heavy oil concentrations.
Posted: 01:19 pm Oct 12 2010
by Mr. Wibbens
Indawoods wrote:50:1 Amsoil Interceptor in EVERYTHING! Even my 4 stroke mower... everything likes it....
Me too, cept mine has 5% Toluene
