I changed plans and opted to go with a 05 KX instead of the 99 I had picked up for the hybrid build. If anyone is considering building a hybrid using a 99 KX chassis I have the following parts. Swingarm already cut with new bearings, front forks with new seals installed, blasted frame which front motor mounts have been removed (surface rust starting to appear), front and rear brake calibers (need rebuilding), sub frame and misc hardware. Any interest simply drop me an email at bouillions@bellsouth.net
Thanks
