Help spring swap!!
chriszeee
Help spring swap!!
Need some help. I just replaced the front springs on my kdx 220 with a race tech 42 weight. The job seamed to go fairly simple...but now that its back together the front end sounds like a squeaky old bed..I reused all the stock parts and put in 5w fork oil. The noise sounds fairly high in the fork tube. I'm not to sure where to start to try and figure out why it makes this noise. On the stock forks I now notice that one end of the spring has a small washer type thing that clips onto the spring..Any help would be appreciated.
Thanks
Thanks
Did you twist the fork tubes onto the cap or just screw the cap on. You should do the former or you will get what you have.
- Colorado Mike
On the bottom...
chriszeee
I've taken them apart again and tried all the above mentioned and the shocks still sound like a pogo stick. I must be missing something here! I have cross referenced the numbers with race tech and they are the correct springs. not only do they sound like a pogo stick if your to shake the tubes you can here the springs rattling around inside.. I have even taken them to a mechanic and it has him baffled..he took them apart as well...arrgggg
Well... it looks like you didn't make new spacers which is the only right way to do it since the length will be different.
A picture is worth a thousand words,
Stock spacers have too much preload. You only want 5-8mm of preload on your springs.
