I am going to do something with my carb, I was going to just send it to RB design, but came across the brand new PWK 35 A.S. carb on his site. I was looking at the pics and there is alittle difference between the stock carb and the A.S. carb. So which one is better or there any difference in performance between the two? I know it would be cheaper to have my carb modified but I would'nt mind having an extra carb around either.
Jon.
OK, Which Carb is Better?
jafo
- jackpiner57
MY KDX 220 R
I have a '05 220, recently installed the following:
FMF -Rev.
Air box lid removal.
Re-jetted stock carb to 150 main.
FRP .40 springs
Body protection etc.
I will be ordering the AS Carb' and the Air Screw that compliments this set-up tomorrow.
If you have a closer look the AS has the extra breathing tubes?? etc .
The exact purpose of which I am not sure, does benefit the entire set up.
Good luck
FMF -Rev.
FRP .40 springs
Good luck
KEEP IT REAL!!
- m0rie
Send off your Head while your at it and have Ron mill and reconfigure the squishband. It up's the compression the 220's and give them a little extra kick.
-Maurice
-Maurice
- KDX220PHIL
MY KDX 220 R,
How do you like the .40 springs, I have the same year/model bike and still trying to decide if i need the .38's or the .40's. How much do you weigh? What type of terain do you ride in? Do you have a lot of riding experience?
I have put this one off for too long now partly due to the fact that I still havn't received my manual yet (ordered it 3 weeks ago), and the uncertainty that the .38 will be alright. I weigh 160lbs. without gear and ride pretty hard.
I had a nasty spill last weekend that resulted in breaking the rear fender and the clamp that holds the clutch lever assembly on the handlebars. I was on a grassy field(short grass, excellent traction). I took off like I was on dirt and the front end came up on me, as I was bringing it back down I was headed for a tree, so I cut the handlebars sideways before the tire had contacted the ground and the front suspension bottomed out, and the rear of the bike, dill-pickle flipped over frontwards. I went rolling with the bike. It was pretty scary but i didnt get hurt too bad, only the bike
. Luckily there was a guy there with me riding a KX250 and he had an extra bracket. I guess being as young as I am , I can take a beating and heal quickly.
Although I hurt the bike, It was an awesome day, and I will be headed back to that same field this weekend.
Hope all goes well.
jafo
- Has thanked: 185 times
If you order it from RB Designs, won't it already have the "RB Designs" modifications to the carburetor?
