For you guys that have drilled out the rear of the swingarm mount on the motor for the larger KX bolt what did you use to drill it out ?
Large drill bit ? what size ?
Thanks T Hill
Swingarm/mount hole
THill
- Tedh98
The machine shop used a 19mm reamer to make the final hole.
Page 3 of this thread has some info on why you'd use a reamer over a regular drill bit.
http://kdxrider.net/forums/viewtopic.ph ... &&start=40
