fork oil level
fork oil level
ok recently i went out to my bike and found that the left fork seal was leaking pretty bad a nice sized puddle under it. so i tried the using the bissness card trick and seeing if there was any dirt in the seal. So after a couple days and riding some it has stoped i think.
So i would like to no if there is any way to check the fork oil level without taking the fork all the way apart. Also can i just take off the cap on the top to add some oil to it? and any idea of how much to add?
- scheckaet
remove the top cap, add oil. dunno what the stock level is, check the manual or check the suspension section.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Mr. Wibbens
pull caps, remove springs, compress forks
Take a stick or ruler and stick it down each fork leg to see what the level is and if they are even
It's not rocket science
Well... not exactly. The tubes should be spun on the caps instead of the other way around.... or else you will put bind on the springs causing an annoying clicking sound.
Ideally they should be off the bike....
- Mr. Wibbens
Unless you have an E
Yes.... If the front end is not supported.... it will slam to the ground too!
